Remove Message Body From Notification
Some of my users are confused when a personal message is sent since the Body of a message is included in the notification email and they are replying to the email instead of using the message system. I want to remove the message and force them to click on link, go to website to see what message was sent (similar to how replies to discussions works).
How do I go about this?
  • I found where the code is I think (/applications/conversations/settings/structure.php), but not sure how to modify this to remove the message so its not visible in the notification and make it upgrade friendly.
    // X sent you a message if ($SQL->GetWhere('ActivityType', array('Name' => 'ConversationMessage'))->NumRows() == 0) $SQL->Insert('ActivityType', array('AllowComments' => '0', 'Name' => 'ConversationMessage', 'FullHeadline' => '%1$s sent you a %8$s.', 'ProfileHeadline' => '%1$s sent you a %8$s.', 'RouteCode' => 'message', 'Notify' => '1', 'Public' => '0'));
  • peregrineperegrine MVP
    edited August 2015
    you would need to experiment. this is just some ideas. so I won't be able to answer follow-up questions.
    if you want to remove the story
    you might try
    $Defintion['EmailStoryNotification'] ='%1\$s\n\n%2\$s';
    but this will affect other activitiy types as well. so it may not be appropriate.
    or you could use plugin
    and trigger off of this event $this->FireEvent('BeforeSendNotification');
    check the activity type equal to conversation message and null out the story(Body) in the Email object . or replace it with a link to your site. or you could.
    or possibly if you could generalize for all emails with stories.
    change the EmailStoryNotification = "%3\$s\n\n%2\$s\n\nPlease don\'t reply to the message via e-mail."
    but you (capital YOU) need to spend the effort to test under all situations, and pursue, since we all would need to do the same thing to see what would be the appropriate way to do things.
    unless of course - someone knows off the top of their head.
  • PFAFFPFAFF
    edited August 2015
    That helped! And, in combination with this post, I figured out I needed to add this:
    $Definition['EmailStoryNotification'] = '%1$s
    Follow the link below to check it out:
    %2$s
    Have a great day!';
    To locale.php.
    Thanks so much!
