Lightbox
I am using Lightbox 2.03.3. Have used it on another website with no problem. My current website is having a problem on the home page. When I click on the picture it brings up the larger picture as normal, but the small pic disappears off the webpage. Lightbox works fine on the other pages.
Will someone look at the site and tell me what I'm doing wrong. http://www.webassistantsllc.com/ffredesign
Sorry I don't have time to play further with this but Safari's Web Inspector exposes all!
What application are you using to write the code, surely it has a visual prompt to show you the error?
Don't tell me you write it by hand!
