Help me troubleshoot this problem
Hi,
My name is Sadish and I have built several themes for WordPress. I support my theme consumers at http://wprocks.com/forums/
whenever people are not logged in, they see this at the top.
// Saved Searches Table Structure
$DatabaseTables['Notify'] = 'Notify';
$DatabaseColumns['Notify']['NotifyID'] = 'NotifyID';
$DatabaseColumns['Notify']['UserID'] = 'UserID';
$DatabaseColumns['Notify']['Method'] = 'Method';
$DatabaseColumns['Notify']['SelectID'] = 'SelectID';
even when I enable or disable an extension, the same messages show up as a javascript alert. how do I solve this?
Look in conf/database.php and remove the ?> before that block of code that you are seeing.
(although he should upgrade to cordless :-)
I was shooting for a cross between that phone and a Merlin when I made the icon.
