Guestsignin
I installed the module guest sign in and when allready subscribed and try to sign in, I get sent to people.php
Can someone help me fix this?
Where is the language loader extension supposed to be? isnt it the same as all the other extensions that are stored in the extensions folder?
When you refer to: <? changed to <?php, you mean in what file?
