Tinymce text color does not work
It is shown in the preview, but as soon as I submit. The color is no longer there. Can someone help?
Is there anything there that I should change?
EDIT: just changed the format to varchar 255 for a try and it still doesn't work.
EDIT2!: tried FCKeditor and getting the same results :-P
EDIT3: HA! Partly fixed it; seems it has to do with the CSS of the theme I'm using (Blogger).
Best,
Ben
