need Major help-Dojo files and attachment
ok so im trying to use dojo files on my forum,i have the attachment mod installed and dojo filees
but when i click files
this shows up
SELECT AttachmentID,Title,Path,LUM_Attachment.Name filename,LUM_Attachment.DiscussionID,LUM_Attachment.Size,LUM_Discussion.Name disc_name,LUM_Attachment.CommentID,LUM_User.Name name,DATE_FORMAT(DateModified, '%D %b ') datoen FROM `LUM_User` LEFT JOIN `LUM_Attachment` USING (`UserID`) LEFT JOIN `LUM_Discussion` USING (`DiscussionID`) WHERE vis = '1' ORDER BY LUM_Attachment.Title ;
Unknown column 'vis' in 'where clause'
any idea
