Issue Tracker Project Filter problem
You can reproduce the problem from Lussumo Community Bugs page.
- first filter on Framework
- then filter on All Projects
But it does not filter all projects, it always go back to Framework (last filtered).
Is this a known issue? any suggestion on how to fix it?
Jun
Jun
//$this->Context->Session->SetVariable('CategoryID', $this->CategoryID);
