Add-ons compatibility. Vanilla experts, help please.
Hi.
I have this new installation, and I need some additional functionality, yet I encounter add-ons incompatibility. I have problems and I hope you can help me solve them. Here are the problems:
1. I need WYSIWYG
2. I need to give users possibility to attach images in comments
3. I need to enable quotes
The the first problem is solved with TinyMCE. But this extension does not solve problem 2, and is incompatible with Quotations and Quote text add-ons. Please help. How do I solve these.
Additional problem arrives when I turn off TinyMCE, and all comments go with HTML tags, instead of formatting. If you could tell me how to make all comments HTML formatted, rather than full of tags, I would also be grateful.
