Help with upgrade from 1.1.4 to 1.1.5a
hey,
this morning vanilla made me check for updates and damn, it found one (1.1.5a).
damn because i was really happy when it all worked just the way it was, but i already knew the day would come when i had to update 1.1.4.
so first i go to getvanilla.com and watch the "upgrade video", but compared to the upgrading instructions text i dont have to do anything like this because my version is newer than 1.x.
ok, so i try to follow the upgrading instructions: i download the new zip-file, unzip and replace all the files named in the instructions. then i try to visit my forum and - a blank site. no idea what happened. bless god i had my 1.1.4 backed up (i was near committing suicide) so i just uploaded the copy and it worked again, but now i still run 1.1.4.
do you have any ideas what i did wrong? im using my own css theme (changed footer) if that could be a problem. or do i have to upgrade to 1.1.5 first, then to 1.1.5a?
i'm very thankful for any suggestions or hints, thx!
