Help with Forced BBCode needed to solve a problem
Hi. I'm trying to set up a simple forum with BBCode-only commands and with the option to insert YouTube video. By reading some discussions on this forum I managed to do so using Forced BBCode + JQuery + JQmedia extensions. Now it can be done just by pasting the the URL.
The problem is, I'd like to do it in a more elegant way - by entering the video's URL amongst BBCode tags:
It already works if you enter it this way:
So I suppose It would work if I changed the BBCode so it converts/treats the [video] tag the same way as it does the [url] tag, but I'm unable to do so. All my attempts in adding such [video] tag to the BBCodeParser.php results in not rendering the link correctly or not rendering the page at all.
I don't know PHP, but I usually manage to change its code to work the way I need. This is one of the cases in which I can't. Can you help me?
[video]http://www.youtube.com/watch?v=dunpHC6CBYo[/video]
[url]http://www.youtube.com/watch?v=dunpHC6CBYo[/url]
I don't know why duplicating the "url" section in BBCodeParser:
'url' => array( 'htmlopen' => 'a',
'htmlclose' => 'a',
'allowed' => 'none^img',
'attributes'=> array('url' => 'href=%2$s%1$s%2$s', 't' => 'target=%2$s%1$s%2$s'))
and replacing the appropriate "urls" with "videos" doesn't work.
Making this out would provide an elegant way to insert videos via BBCode for anyone.
