need help..
Can anyone tell me what this means?
"#2 - Make sure you set the upload folder to chmod 777."
It's part of the 'additional instructions' listed on the YUI Editor Add-On Info Page in the add-ons section...
Thanks,
Mark
Thanks,
Mark
Now all I got to do is figure out how to get a default.php file for the YUI editor and maybe I can try it out...
I hope it is a little more useable than the TinyMCE editor after going through all this to get it working... :-)
Thanx again,
Mark
