Need a recommendation for Private Messaging system
Hi everyone,
I would like some recomendations for a private messaging system.
I've seen 2 extensions for a private messaging system.
1) UserMessages
2) PrivateMessages
I've tried both but have different thoughts. UserMessages creates messages from the new discussion link on the side which auto fills usernames into the whisper field, but it has an inbox tab at the top that doesn't lead to the mailbox (dead link). Private Messages has a private message link instead of using the start new discussions (which i prefer it having it's own link) and it uses the inbox link at the top of the page properly but it doesn't auto fill user names in. Neither extension provides some sort of method of cleaning out your inbox (aka delete) and neither one notifies you that you have mail waiting from what I can tell.
Could someone please make some suggestions. Thanks!
Vanilla comes built-in with a Private Messaging system. All a user has to do is whisper a discussion to the user they wish to have a private conversation with.
Forums are supposed to be fairly public by nature. If you want a "private" discussion with multiple people, you can use Email
I also recommend disabling all your other "Whisper" feature-changing extensions as they might conflict with each other.
Nobody likes change, but people will be more open to it when you explain it's a change for the better Also, a good idea might be to explain in detail what has changed and how to accomplish the same task on the new system.
