Need help with odd extension message
Hi,
I installed vanilla (1.1.5a), everything went well but I wanted
to be able to add images to comments, so
a added the extension attachements 2.1. But wenever I try to enable
the extension. A message box pops up showing me this
<!-- www.000webhost.com Analytics Code -->
<script type="text/javascript" language="javascript">
......I removed this part for clarity......
</noscript>
<!-- End Of Code -->
And this happens when I tick the checkbox ON or OFF of every extension I tried.
Reinstalling vanilla didn't help. The extensions don't work because of this.
Here a small directory tree:
root (public_html) directory is wordpress 2.7 is installed
--forum directory (containing vanilla)
--conf chmod 777
--extensions chmod 775
--Attachments chmod 775
etc..
I am new to vanilla.
So my question is, how can i fix this?
Tia fman
