Global Preference for FCKeditor...help please
I have successfully installed FCKeditor and the Global Preferences addon. What I need to know now is how to enable FCK for all users. In the Extensions Options there is a field to enter the preference name to change and another to enter a value (0 or 1). How do I know what the name of the preference to change and is this where I should be doing it? I've very new at this (only 2 days working on it). Do I need to manually change a file or can I do everything in the Global Preferences extension? Thanks in advance for any help.
