Big Problem.. Compression Error
I tried installing MooTools on my Vanilla 1.1.5 install and then came up with an "The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression." error in Firefox, safari and any other browser I used.. I unchecked the extension, deleted it... but im still getting this error. I cannot access my forum at all, did some critical file get messed up?
Here's the site in question: http://www.deskvibe.net/
Warning: include(/www/110mb.com/d/e/s/k/v/i/b/e/deskvibe/htdocs/extensions/Mootools/appendix.php) [function.include]: failed to open stream: No such file or directory in /www/110mb.com/d/e/s/k/v/i/b/e/deskvibe/htdocs/conf/extensions.php on line 30 Warning: include() [function.include]: Failed opening '/www/110mb.com/d/e/s/k/v/i/b/e/deskvibe/htdocs/extensions/Mootools/appendix.php' for inclusion (include_path='.:/usr/share/php') in /www/110mb.com/d/e/s/k/v/i/b/e/deskvibe/htdocs/conf/extensions.php on line 30
open conf/extensions.php and remove line 30. Also, are you using an extension to compress your page?
$Configuration['LOWCALVANILLA_GZIP_ALLOWED'] = '0';
Which version are you using? How do you compress the page?
