Modification of a parser (on first comment)
Hello all,
first, love the software!
second, any PHP wiz who can help me out?
i'm using Make It Simple Text Formatter 1.12 ( http://lussumo.com/addons/index.php?PostBackAction=AddOn&AddOnID=399 ) and i'm trying to customize it so that it only parses at the 1st comment of each discussion.
I figure a simple:
if post = #1 ( parse )
else ( ignore )
would work?
here's the code:
thanks! ^^
I figure a simple:
else ( ignore )
would work?
here's the code:
if (in_array($Context->SelfUrl, array("comments.php", "post.php"))) {
// An implementation of the string filter interface for plain text strings
class ExtendedTextFormatter extends StringFormatter {
function Parse ($String, $Object, $FormatPurpose) {
$sReturn = $String;
// Only format plain text strings if they are being displayed (save in database as is)
if ($FormatPurpose == FORMAT_STRING_FOR_DISPLAY)
if (stripos($sReturn, 'http://') !== false)
$sReturn = $this->AutoLink($sReturn);;
return $sReturn;
function AutoLink($String) {
$String = str_replace(array(""","&"),array('"','&'),$String);
$SplitLines = explode("<br />", $String);
foreach ($SplitLines as &$Line) {
$SplitWords = explode(" ", $Line);
foreach ($SplitWords as &$Word) {
if (strncasecmp($Word, 'http://', 7) == 0)
if (strcasecmp(substr($Word, strlen($Word) - 4), '.jpg') == 0 || strcasecmp(substr($Word, strlen($Word) - 5), '.jpeg') == 0 || strcasecmp(substr($Word, strlen($Word) - 4), '.gif') == 0 || strcasecmp(substr($Word, strlen($Word) - 4), '.png') == 0) {
$Word = '<img src="'.$Word.'" class="discImg" />';
} else if (stripos($Word, 'youtube.com/watch?v=')) {
$Word = '<embed src="http://www.youtube.com/v/'.substr(stristr($Word, '='), 1).'" type="application/x-shockwave-flash" width="448" height="361"></embed>';
} else if (stripos($Word, 'dailymotion.com/video/')) {
$IDStart = strpos($Word, 'video/') + 6;
$IDLength = strpos($Word, '_') - $IDStart;
$DailyMotionID = substr($Word, $IDStart, $IDLength);
$Word = '<embed src="http://www.dailymotion.com/swf/'.$DailyMotionID.'" type="application/x-shockwave-flash" width="448" height="357" allowFullScreen="true" allowScriptAccess="always"></embed>';
} else if (stripos($Word, 'video.google.com/videoplay?docid=')) {
$Word = '<embed id="VideoPlayback" style="width:448px;height:362px" allowFullScreen="true" src="http://video.google.com/googleplayer.swf?docid='.substr(stristr($Word, '='), 1).'" type="application/x-shockwave-flash"> </embed>';
} else if (stripos($Word, 'index.cfm?fuseaction=vids.individual&videoid')) {
$Word = '<embed src="http://lads.myspace.com/videos/vplayer.swf" flashvars="m='.substr(stristr($Word, 'videoid='), 8).'&v=2&type=video" type="application/x-shockwave-flash" width="430" height="346" />';
} else if (stripos($Word, 'spike.com/video/')) {
$Word = '<embed width="448" height="365" src="http://www.spike.com/efp" quality="high" bgcolor="000000" name="efp" align="middle" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="flvbaseclip='.substr(strrchr($Word, '/'), 1).'" allowfullscreen="true"> </embed>';
} else if (stripos($Word, 'redlasso.com/ClipPlayer.aspx?id=')) {
$Word = '<embed src="http://media.redlasso.com/xdrive/WEB/vidplayer_1b/redlasso_player_b1b_deploy.swf" flashvars="embedId='.substr(stristr($Word, '='), 1).'" width="390" height="320" type="application/x-shockwave-flash" allowScriptAccess="always" allowFullScreen="true" name="Redlasso"></embed>';
} else if (stripos($Word, 'ceknito.sk/video/')) {
$Word = '<embed src="http://www.ceknito.sk/style/vp.swf" type="application/x-shockwave-flash" width="440" height="365" flashvars="fid=000a/'.substr(stristr($Word, '/video/'), 7).'" allowFullScreen="true" />';
} else if (stripos($Word, 'vii.sk/video/')) {
$Word = '<iframe src="http://www.vii.sk/embed/'.substr(stristr($Word, 'vii.sk/video/'), 13).'" width="448" height="336" frameborder="0"></iframe>';
} else if (stripos($Word, 'vimeo.com/')) {
$Word = '<embed src="http://vimeo.com/moogaloop.swf?clip_id='.substr(stristr($Word, 'vimeo.com/'), 10).'&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="448" height="336"></embed>';
} else if (stripos($Word, 'videos.onsmash.com/v/')) {
$Word = '<embed src="http://videos.onsmash.com/e/'.substr(stristr($Word, '/v/'), 3).'" type="application/x-shockwave-flash" allowFullScreen="true" width="448" height="374"></embed>';
} else {
$Word = '<a href="'.$Word.'" target="_blank" rel="nofollow">'.$Word.'</a>';
unset($Word);
$Line = implode(" ", $SplitWords);
unset($Line);
$String = implode("<br />", $SplitLines);
return $String;
$ExtendedTextFormatter = $Context->ObjectFactory->NewObject($Context, "ExtendedTextFormatter");
$Context->StringManipulator->Formatters[$Configuration["DEFAULT_FORMAT_TYPE"]]->AddChildFormatter($ExtendedTextFormatter);
$Head->AddStyleSheet('extensions/MakeItSimpleTextFormatter/style.css');
thanks! ^^
I've seen some previous attempts to try this, like changing the style for the first comment, but that was done inside the comments.php.
I also found the $RowNumber variable. Could it be used inside this extension?
if (in_array($Context->SelfUrl, array("comments.php", "post.php"))) { ... $firstCommentID = 0; function Discussion_GetFirst(&$DataSet){ global $firstCommentID; $firstCommentID = $DataSet->FirstCommentID; } $Context->AddToDelegate("Discussion", "PostGetPropertiesFromDataSet", "Discussion_GetFirst"); ... class SomeFormatter extends StringFormatter { function Parse ($String, $Object, $FormatPurpose) { global $firstCommentID; if($firstCommentID && $Object->CommentID==$firstCommentID && $FormatPurpose == FORMAT_STRING_FOR_DISPLAY){ //Do your parsing } return $String; } ...
thing is, what i really want is to have the parser work for images and videos for the 1st comment and for the other comments just parses the links normally without embedding images or videos.
// edit: ok the code i pasted here was rubbish :-)
so, any ideas how to implement it? ^^
if ($FormatPurpose == FORMAT_STRING_FOR_DISPLAY){
if($firstCommentID && $Object->CommentID==$firstCommentID){
$String = $this->AutoLink($sReturn,true);
}else{
$String = $this->AutoLink($sReturn,false);
return $String;
function AutoLink($String, $First) {
", $String); foreach ($SplitLines as &$Line) { $SplitWords = explode(" ", $Line); foreach ($SplitWords as &$Word) {
if(strncasecmp($Word, 'http://', 7) == 0){
if ($First){
$Word = '';
} else {
$Word = '->link<-</a>';
}else{
unset($Word);
unset($Line);
$String = implode("
", $SplitLines);
return $String;
gonna try to implement
<?php
Extension Name: Make It Simple Text Formatter
Extension Url: http://lussumo.com/addons/index.php?PostBackAction=AddOn&AddOnID=399
Description: Extends the default text formatter to autolink urls and auto insert images and videos.
Version: 1.12
Author: Gambit
Author Url: http://www.burrrn.net/
Copyright 2008 Gambit
This file is part of Lussumo's Software Library.
Lussumo's Software Library is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
Lussumo's Software Library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with Vanilla; if not, write to the Free Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
The latest source code is available at www.lussumo.com
if($firstCommentID && $Object->CommentID==$firstCommentID){ $String = $this->AutoLink($String,true); }
else { $String = $this->AutoLink($String,false); }
return $String;
", $String);
if(strncasecmp($Word, 'http://', 7) == 0) {
if ($First){
$Word = '
500) {this.width = 500;}" class="discImg" />';
$Word = '';
$Word = '';
$Word = ' ';
$Word = '';
$Word = ' ';
$Word = '';
$Word = '';
$Word = '';
$Word = '';
$Word = '';
} else {
$Word = ''.$Word.'';
} else { $Word = ''.$Word.''; }
unset($Word);
unset($Line);
$String = implode("
", $SplitLines); return $String; } } $ExtendedTextFormatter = $Context->ObjectFactory->NewObject($Context, "ExtendedTextFormatter"); $Context->StringManipulator->Formatters[$Configuration["DEFAULT_FORMAT_TYPE"]]->AddChildFormatter($ExtendedTextFormatter); } ?>
