Administrator stuck with default forum style?
muppet
Hey folks,
When, as a forum administrator, I access the "Settings" tab and then change the style and click save, I still see the default forum style (the last style I applied to all users) unless I set a new default style by clicking "apply to all users".
Am I misunderstanding how this functionality works? How do I set one style to be the default that new members see, while having a different style for myself?
conf/settings.php
file. Beware however, you must know the exact location and name of the style you want to change.Look for/add
'DEFAULT_STYLE'
and'THEME_PATH'
.'DEFAULT_STYLE'
is the URL to the stylesheets folder (not directly to the css file).'THEME_PATH'
is the absolute path on the filesystem to the folder containing the php files for the theme.
