Login issue, directing wrong location
edited May 2009 in Vanilla 1.0 Help
Hi there, I'm having some trouble with the forum. Whenever someone logs in they get directed to: http://://correctcraft.ca/ - I'm pretty sure everything is configured correctly on my end - it just seems to be using the wrong redirect path. Thanks, David
  • I had the same problem, found the solution here: http://lussumo.com/community/discussion/8294/login-error-when-calling-the-peoplephp-file/#Item_14 you'll have to edit conf/settings.php
  • Oh interesting - thank you. Now I'm noticing whenever I try logging out I get a blank page. There is likely an error being produced but I'm not sure how to make it visible to provide more details. Anyone have this particular issue? I've tried searching the forums with no success on similar issues. Thanks, Dave
