whispers won't enable...help
When I'm signed into vanilla and go to the application settings, I check the box by enable whispers and when I click the save button, the check box is no longer checked. It's kind of annoying to say the least.
I don't know what could be causing this.
Forum is at www.epochchurchjax.com/forum
Can someone help me with this?
If not, you may need to change the permissions of your
conf/settings.php
file. Make sure the webserver can read and write to it.vanilla:administrators:installation
