Problem with Framework.Functions function ForceIncomingInt does not allow 0 value
Hello,
I'm using this function, ForceIncomingInt, which should force integers to be 0 or greater. Unfortunately I have found that a function called from this function, ForceInt, prevents the incoming integer from being 0. The problem can be seen in the code:
function ForceInt($InValue, $DefaultValue) {
$iReturn = intval($InValue);
return ($iReturn == 0) ? $DefaultValue : $iReturn;
intval returns the integer value of $InValue, or it returns 0 for a failure case. SO if $InValue == 0 then the following result check will assume a fail and the $DefaultValue will be returned.
I guess that adding this line to the beginning of ForceInt will fix the problem:
if ($InValue == 0) return 0;
The workaround, if you need 0, is to set $DefaultValue to 0. Not ideal however the only way I can see to get around this.
return ($InValue > 0 || $InValue === 0) ? $iReturn : $DefaultValue;
PHP's typecasting would make your test return
(int)0
even if the$InValue
were(bool)false
.return ($iReturn > 0 || $InValue === 0) ? $iReturn : $DefaultValue;
