How would I go about setting a minimum length to posts and comments?
Is there an existing plugin to do so? Or any easy edits?
  • actually!!!
    To Vinilla 2 where to establish the minimum quantity of symbols in the comment?
  • vanilla/settings/floodcontrol
    in your dashboard.
    actually that is maximum
    UnderDog
  • peregrine said: vanilla/settings/floodcontrol
    in your dashboard.
    You speak to me as to establish the maximum length of the message, and I need the minimum value. Where to establish the minimum value?
    Example:
    the maximum quantity of signs - I establish 1500.
    And minimum it turns out can be and 1 sign or 1 smilie how to make that users couldn't write less than 100 signs for example???
    Вы мне говорите как установить максимальную длину сообщения, а мне нужно минимальное значение. Где установить минимальное значение?
    Пример:
    максимальное количество знаков - устанавливаю 1500.
    А минимальное получается может быть и 1 знак или 1 смайлик, как сделать чтобы пользователи не могли написать менее 100 знаков например???
  • You are absolutely right - I commented about the wrong thing. I don't have an answer to solve what you want to do.
  • peregrine said: You are absolutely right - I commented about the wrong thing. I don't have an answer to solve what you want to do.
    Yes here now I will check at this forum, I will put in the following message 1 sign, whether we will see the comment will be published. ;)
    Whether there is at whom an answer to my question?
    Да вот сейчас проверю на этом форуме, поставлю в следующем сообщении 1 знак, увидем будет ли опубликован комментарий. ;)
    Есть ли у кого ответ на мой вопрос?
  • As we see users can quietly leave senseless comments with 1 sign.
    Как видим пользователи могут спокойно оставлять бессмысленные комментарии с 1 знаком.
  • 422422 Developer MVP
    If you notice, type nothing and hit post comment. Validation, kicks in. So you could add this as a jquery character count min to vanilla buttonbar i would assume.
