Pre-Moderation: Comment approval and Discussion Approval messages display wrong
edited August 2009 in Vanilla 1.0 Help
Browser/OS: Firefox 3.0.13 on Mac OS X 10.5.8 with Vanilla 1.1.8
Level: Defect/PHP notices
Hi all,
I'm running a test server with Pre-Modification add-on. After posting comment, user gets messaging saying "Thank You!" and the wait until "approved by a moderator." Unfortunately, the page display looks bad... as the
[body id="ExtensionPage" ]
I'm using [ and ] above to display it and XXXXXXX for the URL prefixes below
doesn't pick up any of the custom CSS that is with my modified theme (based on Bushido's fixed width Vanilla). The defects in page display include the following: No top Nav Tabs, Resized header image, and changed "Start a new discussion" text.
The code is derived from
./extensions/PreModeration/default.php lines 32-34 and build up of code from same file in lines 280-310... going out to ./exensions.php
I'm getting no Header, BannerTitle, Navbar, TabOn div id, classes, etc.
./conf/settings.php is correctly set up and everything else works. All of the other pages and forms are fine with one exception:
I'm getting the following two error messages in the Pre-Moderation APPROVE window in Settings:
Notice: Undefined variable: Context in /home6/askthec2/public_html/artseducation/socmed/extensions/PreModeration/ThemeFiles/premoderation_form.php on line 28
Notice: Trying to get property of non-object in /home6/askthec2/public_html/artseducation/socmed/extensions/PreModeration/ThemeFiles/premoderation_form.php on line 28
AND in the Pre-Moderation DENY
Notice: Undefined variable: Context in /home6/askthec2/public_html/artseducation/socmed/extensions/PreModeration/ThemeFiles/premoderation_form.php on line 52
Notice: Trying to get property of non-object in /home6/askthec2/public_html/artseducation/socmed/extensions/PreModeration/ThemeFiles/premoderation_form.php on line 52
What can I do to help this essential add-on to work with the theme CSS and build a properly formatted PostBackAction=CommentApproval?
TNX DDF
  • OK, did I do something wrong here? Is this posted in the wrong place? Can someone at least give me a direction to move forward on this?
    Other people are using Pre-moderation?
