Sign in problems
edited August 2009 in Vanilla 2.0 - 2.8
i just realised that when i try to sign in from my main homepage the return url keeps changing to http://://www.mydomain.com
its really annoying any suggestions on how to fix this?
    hi !
    I had the same trouble by login and with some other links (bottom page and, i don´t know anymore !)
    I just maked a search with for :// into the whole vanilla scripts and I found a fonction that add this :// and commented it.
    Can´t help you further more because it was for one or two weeks ago, but without knowledge of php I have resolv my problem, so i think you can it too ;)
    do you remember which file it was in?
