Jump to first unread comment
tmilovantmilovan New
edited August 2010 in Vanilla 2.0 - 2.8
I see that Vanilla 1 had Jump to first unread comment option so users are redirected to first unread post when click on discussion link. I don't see that in Vanilla 2. Is there any way to enable that behaviour?
    Found out myself. I had to change:
    $Configuration['Vanilla']['Comments']['AutoOffset'] = FALSE;
    to TRUE in config.
    RaizeRaize vancouver ✭✭
    Thanks, good tip.
    configuration.php file is located in
    applications/vanilla/settings
    NOTE: this configuration is changed automatically with the Voting plugin, so enabling or disabling that plugin will reset your configuration.
