[Solved] Is there a way to create sub-forums?
edited October 2011 in Vanilla 2.0 - 2.8
What if I want to create a forum inside another? Is that possible?
Or even group a number of forums together as in:
Sports Forums:
- Football
- Basketball
Technology Forums:
- Computers
- Gadgets
and so on..
    ToddTodd Chief Product Officer Vanilla Staff
    Answer ✓
    Go to your dashboard and click categories. In your categories list you can drag and drop the categories into a tree like structure like you want. Just drag a category to the right a little to put it underneath another one.
    Answer ✓
    Thanks Todd. Worked perfectly.
    worked great
    yes, it works! awesome! thanks, todd.
