The problem with Russian characters Б
edited June 2011 in Feedback
When I try to add a tag with the letter "б" is added to only a portion of the tag. For example: дерижабль = дерижа
Then, after the letter "б" begins a new tag
example: дерижа, ль
sorry for google translate...
    SS ✭✭
    Answer ✓
    "б" is comma, acts as space, tab or return. Comment line ~ 180 @ jquery.tokeninput.js
    case KEY.TAB:
    case KEY.RETURN:
    //case KEY.COMMA:
    case KEY.SPACE:
    if (selected_dropdown_item) {
    add_token($(selected_dropdown_item));
    SS ✭✭
    Answer ✓
    case KEY.TAB:
    case KEY.RETURN:
    //case KEY.COMMA:
    case KEY.SPACE:
