Problem with Split-merge and QnA addons
vaniller
When I'm try to split 2 commnets into a new discussion, I'm getting error message:
"Choose either whether you want to ask a question or start a discussion." but in Split-merge addon isn't any optiont to chose type.
I need some simple hack to set this type permanently as "Discussion", maybe someone can help to do this ?
I'm having this same problem. Did you find a solution?
No, just didn't use Split-merge, but You should try new version QnA relased today.
Mind filing an issue on GitHub?
https://github.com/vanillaforums/Garden/issues/1233
