Generate Meta Desc from Post Content and Comment
psycheangel
Change in function DiscussionController_Render_Before
from this:
array_walk($tags, 'strip_tags'); array_walk($tags, 'trim'); array_walk($tags, 'htmlspecialchars'); $tags = array_unique($tags); if ( count($tags) > 0 ) { $Sender->Head->AddTag('meta', array('name' => 'keywords', 'content' => implode(', ', $tags))); } $Sender->Head->AddTag('meta', array('name' => 'description', 'content'=> $Sender->Data('Discussion.Name'))); $data = array ( 'title' => $Sender->Data('Discussion.Name'), 'category' => $Sender->Data('Discussion.Category'), ); $type = 'discussion_single'; $this->ParseTitle($Sender, $data, $type);`
to this :
$PageNum = ($Sender->Pager->Offset / $Sender->Pager->Limit) + 1; if($PageNum > 1){ $CommentData = $Sender->Data('CommentData')->Result(); $Description = strip_tags($CommentData[0]->Body); } else { $Description = strip_tags($Sender->Data('Discussion.Body')); } if(strlen($Description)<1){ $Description = $Sender->Data('Discussion.Name'); } else { $Description = explode(' ', $Description); $Description = array_slice($Description,0,40); $Description = implode(' ',$Description); } $Sender->Head->AddTag('meta', array('name' => 'description', 'content'=> $Description)); $data = array ( 'title' => $Sender->Data('Discussion.Name').' - Page '.$PageNum.' ', 'category' => $Sender->Data('Discussion.Category'), ); $type = 'discussion_single'; $this->ParseTitle($Sender, $data, $type);</code>
Modify for :
If not first page of Discussion will grab from first comment data in that page
Change to Title Tag to add Current Page Number of Discussion
hope, this will be useful for someone
-1
