Problem logging into dashboard. Please help.
edited February 2012 in Vanilla 2.0 - 2.8
Hi,
I've recently installed VF at http://www.photography.net/community/
I used to be able to get to my dashboard at http://photography.net/community/dashboard/settings It no longer seems to work and I cannot login to edit my settings. I'm new to all this. Help appreciated.
Thanks,
J.D.
  • x00x00 MVP
    Answer ✓
    You have to select the database first or
    UPDATE `DatabaseName`.GDN_User SET `Admin`=1 WHERE `Name` = 'YourUserName'
  • x00x00 MVP
    Do you remember who is the default admin?
    You can execute this query in phpMyAdmin:
    UPDATE GDN_User SET `Admin`=1 WHERE `Name` = 'YourUserName'
  • edited February 2012
    @x00 Thanks for the response. I'm not sure how to do what you suggest. I do know my User name, Database Name, and Password. The problem is when I try to go to my dashboard which I think is at www.photography.net/community/dashboard/settings it just takes me to the forum user sign-in screen instead of my dashboard.
    I tried doing a query in phpAdmin but clearly don't know what I am doing.
  • x00x00 MVP
    Answer ✓
    OK. I found what I needed in phpMyAdmin. Thanks for your help.
