Problem with NillaBlog and posting
Hi, I am using your theme also a Nillablog plugin but each time i create a topic and i post it, there is 2 contents.
I mean if i write test 123, after post, it appears like test 123 test123.
you can check it here
Interesting, I also note the background images loading rather slow, or not at all. I think I had a problem with this some while ago (I have been so busy with school recently I haven't check up on this site in ages) I honestly can't remember, try nillablog without the theme, and try the theme without nillablog. To see which is the culprit, I am pretty sure I did test this with nillablog and it was okay.
