small problem with this plugin
alichakery
Hello,
First let me thank you for this great theme.. it really saved my day...
but I have a minor issue with it, and its about "options" menu beside the discussions ..
here is the example : http://niaz.org/vanilla/
I installed an Persian language to test the theme ...
you help is really appreciated ... thank you
This book helps you if you're working on a Persian forum.
It seems you're using another theme, now (Nov 26). However I tested VanillaAR. There's some missing codes in its style.css file. Add these codes at the end of
/themes/VanillaAR/design/style.css
file:Above codes come from
/applications/dashboard/design/style.css
file.Thanks guys
