Help, Porter giving me an error
I'm exporting a php 3.0.9 with the Vanilla2Export.php
I keep getting this error
Fatal error: Call to undefined function date_default_timezone_set() in /var/www/html/forum/vanilla2export.php on line 5081
Does anyone know how to fix this?
    Requirements:
    PHP 5.2.0 or newer
    php3? seriously I didn't know anyone ran that any more. php4 was released 12 years ago.
    I think it's a typo. That should probably mean phpBB 3
    date_default_timezone_set was introduced around php 5.1
    Yeah, your arguement is still valid. The php needs to be updated but probably not from version 3 ;)
    for phpBB I recommend using my porter to sort out the quirks
    https://dl.dropbox.com/u/15933183/porterplus/porterplus.php
    and remember to add quotes plugin for quotes.
    however this won't sort this problem out. You have to set up the correct version.
