weird problem
Chad_Abizeid
When I enable this add-on, the orange circle "replies" count is missing on the home page.
http://community.logicweb.com/
As soon as I disable the mod, it returns. I have not idea why it's causing such an odd conflict.
Most probably some CSS that applies a white background to the Replies element. You should be able to verify this using Firebug, and determine which CSS class should be modified.
Correction
I just noticed that you posted the address of the site and I had a look at it. It doesn't seem to be a CSS issue, the element displaying the amount of replies is missing entirely. In this case, I guess that the issue may be due to some event handler introduced by the Voting plugin, which alters the page output. Unfortunately, I can't give more details as I would have to compare the theme and the plugin to find out what's happening.
My shop | About Me
because voting.css line 108 has
div.Meta span.CommentCount {
display: none;
Thanks @peregrine that was it
