[Solved] Upgrade Problem from 2.0.1 to 2.0.18
itrcp
Hi All,
I have one serious problem with my seoforum1.com as I upgraded it as following the steps mentioned here http://vanillaforums.org/docs/installation-upgrade but no luck , then I deleted all the files from my hosting and uploaded the new version , I am using the same old Database but no discussions are visible on the front end . database is connected and working fine users are there .
but no discussion any suggestion please
I have destroyed my Live Forum
I can see them, did you check your roles and permissions?
My suggestion is to use the porter plugin to export all your information first. That's your backup and restoring it using the porter plugin would be one of your options.
After you installed 2.0.18.8, did you run utility/update again? Or utility/structure?
Shouldn't you upgrade to earlier versions first before you upgrade to 2.0.18.8?
can you upgrade to
http://vanillaforums.org/addon/vanilla-core-2.0.17
first then to
http://vanillaforums.org/addon/vanilla-core-2.0.18.8
thanks for your help guys I reverted back to the old backup. As I am not sure what will work , as I have tried update utility , I did clean cach .ini files . every thing I test
so I think now I should try the plugin mentioned by UnderDog Porter plugin .
let see what happens
Try to do an upgrade on your local PC first and if that works, upgrade on your live site.
There must be a way to do an upgrade without using the porter plugin. But upgrading from 2.0.1 means upgrading first to older versions and then to 2.0.18.8, like x00 says.
Hi guys , I got it fixed just to share what I did .
I removed all the plugins after taking the backup of all of them . then I have uploaded all the new version default plugins and uploaded .
after that I uploaded the missing plugins and it start working .
the problem was with someone of the plugin old version . but don't know which one was the culprit .
thanks
