[Solved] Themes don´t work, Smarty Problems*
rolorolo New
edited December 2013 in Vanilla 2.0 - 2.8
The only theme that work for me is the default one.
All other themes don´t show the style (see attachement images)
Vanilla Version 2.0.18.8, tested 2 themes: Simple, White & Bootstrap themes
Can u help me?
Thanks!
    Bootstrap theme has specific instructions to follow - see the readme.
    All other themes don´t show the style (see attachement images)?
    does embed theme work? You might try downloading a couple of themes, and see if they work.
    and clear the .ini files from your cache and disable any minify or page speed plugins.
    I downloaded 2.0.18.9 and had the same issue. I turned added $Configuration['Debug'] = TRUE; in the config file and found that the /cache/Smarty/compile directory was not writable.
