Smarty problem
phalc0nline
Hi!
1.Why when I write {$User|@var_dump} or {'test'|@var_dump}
application crashed with message:
"Something has gone wrong.
We've run into a problem and are unable to handle this request right now.
Please check back in a little while."
2.
{php} var_dump('test'); var_dump($User); echo 'test''; {/php}
hothing happens...(
3.
{php} $var = $this->get_template_vars('var'); var_dump($var); {/php}
Apache log:
PHP Fatal error: Call to a member function get_template_vars() on a non-object in /var/www/html/Vanilla-bootstrap/cache/Smarty/compile/vanilla^%%FD^FDB^FDB7A827%%default.master.tpl.php on line 83, referer: http://vb.loc/
P.S. LAMP + Smarty already installed.
Enable debug mode by adding
$Configuration['Debug'] = TRUE;
to your/conf/config.php
file. That will give you more information when you see a "Something has gone wrong" page.IIRC, Vanilla has the
{php}
smarty tags disabled.Search first
Thank you!
How I can enable
{php}
or{$User|@var_dump}
?Use the
{debug}
tag to get information on the Smarty environment.Search first
Great, it's work.
{$var|@debug_print_var}
Can I set enable
{php}
? It's possible?There is no reason to use smarty if you are going to use the
{php}
tag.Either make your output stateless (like the template wants) or make a function and register the smarty tag via a plugin (like my previous link suggests).
What are you trying to accomplish?
You might be interested in creating your own Smarty functions: http://vanillaforums.org/discussion/27767/how-to-create-custom-smarty-functions#latest
I just realized I didn't link to that like I thought I did.
You did already and I would have cited you if I saw it first
http://vanillaforums.org/discussion/26188/how-to-modify-the-layout-of-the-panel-asset#latest
Thank you. I followed your advice and all work perfect. That's all what I needed.
