[BUG] Firefox show "Body is required."
This Bug only appears in Firefox, Chrome works well.
If you try to insert an Comment, there is the message: "Body is required."
See Screenshot: http://minus.com/lbp6VvaWqHEGSe
    This is an issue with cleditor (also called WYSIWYG editor).
    I thought it was only an issue with IE though.
    Upgrading the underlying version of cleditor will fix this, IIRC.
    TL;DR use button bar.
    suthersuther New
    edited February 2015
    What you mean with use button bar? Is there a way to upgrade the CLEditor with one click in the Backend?
    Ahh, I see its another Plugin. Thanks, that works well.
