How to Fix error Duplicate entry '6-8'
jobbatamjobbatam Batam New
edited May 2015 in Vanilla 2.0 - 2.8
Hello, i need help here,
I dont how to describe this problem, but i can tell by image
when i go to http://www.mydomain.com/dashboard/user/applicants to approve new member, i see errot like this:
Duplicate entry '6-8' for key 'PRIMARY'|Gdn_Database|Query|insert GDN_UserRole (UserID, RoleID) values (:UserID, :RoleID)
for some member
Other member no error notification (work fine) but, when i approve rule of member go blank like this :
I use roletitle and yaga rank..
before this error, i install vanilla twice because i delete config.php file in /conf
thanks for your best help because i dont know to fix this issue, and i dont know where best place i can ask.
    R_JR_J Ex-Fanboy Munich Admin
    You really, really, really, really should not publish the mail addresses of your users!
    edited May 2015
    i m sorry, i will replace it.. soon
    thanks for your attention
    but to late,,
    oh no..
    but, can you help me mr @R_J ?
    @jobbatam
    I've deleted those images.
    If you add new ones in a subsequent post, I'll add them back into the post.
    Check if the applicants UserIDs are already in table GDN_UserRole. That might have happened because you have installed Vanilla multiple times
    edited May 2015
    @whu606 said:
    jobbatam
    thanks for your help, i have insert new image, please keep in the first discussions =)
    I find this code in class.rolemodel.php but i don't know What should I do? i tired to install again this vanilla forum, I want the existing running as it should..
    Probably as a result of deleting things directly in the database, the auto index has go messed up.
    yups, the second installation i just take config.php, after that i replace new installation database with older database.. but now there is fatal error in user database, i searching solution how to import discussion with registered member and found vanilla porter, thats really hard for me work with cpanel because i m not webmaster background. please someone can help me, i tired to choose third istallation as solution.
    The duplicate index is probably referring to two record in the GDN_UserRole table with UserID of 6 and RoleID of 8. This is just a guess, but I would suggest looking for duplicate records and removing them.
    Also, if you don't have default roles set up, your users will not have a role when they are approved.
    Be sure to set up default roles at //forums.example.com/dashboard/role/defaultroles
