Using jsConnect - Login, Logout, Registration links not redirected.
sottwell
Vanilla 2.1.10 with jsConnect 1.4.1
The login works fine with a MODX site. But the links in Vanilla for login, logout and register are still set to the Vanilla popups and pages. I have added lines to the config.php file, as suggested in one forum post. The links don't change. I have set the Registration method to "Connect", that seems to have only hidden the login and register buttons in the sidebar "meModule" block. Using the {signinout_link} in the main menu still links to the Vanilla services. I need at least some kind of logout link. I've triple-checked the URLs I put in the jsConnect configuration. After six hours of searching and trying different things I'm out of things to try.
What configurations did you set?
For jsConnect?
The URLs are all valid, I've checked them repeatedly. All in the form of
http://domain.com/page.html
Trusted connection - check
default signin method - check
hash algorithm - sha1
test-mode - no
As I said, the login itself works great. I'm just baffled that it's not respecting the plugin's URL overrides for the login, logout and registration links.
What configuration keys have you set in your
/conf/config.php
file?Search first
