I need help changing vanilla routes
xm1
For some very important reasons that has to do with integration, I need to change the vanilla default discussion route from siteurl.com/discussion/123/post-slug
to something likesiteurl.com/custom/123/post-plug
I have tried changing the routes from the dashboard->Routes (DefaultController and DefaultForumRoot), but when I change them, it breaks the forum.
Thanks.
Welcome to the community!
This seems like a terrible idea, but you can totally do it!
CustomController
where Custom is replaced by your pathRoute: ^discussion(/.*)?$
Target: custom/?$1
Ok @hgtonight
Why do you think its a terrible idea?
How do I create an application?
in answer to this question....
there was a document on creating vanilla applications and an example application. It was in the old user documentation.
http://vanillaforums.org/discussion/22955/application-development-how-to
Also, it may (or may not) be in the "latest" documentation. you could check the documentation link at the top of the page in the navigation menu.
I think it is a terrible idea because any plugin that writes URLs manually and/or extends the discussion controller might not work. I can't think of a really good reason to change the name of a controller excepting to translate the URL.
There was a sample application bundled with Vanilla called skeleton that broke down what you could do. It isn't up to date, but there is some good information in there: https://github.com/vanilla/vanilla/tree/05e655647f3eb3f7a526dd73a8b4147d8698e5e3/applications
Remember that Vanilla is just an application too.
@hgtonight he wanted to root controller discussion. I already answer his question here:
http://vanillaforums.org/discussion/comment/234590/#Comment_234590
No need to create an application in this case. Not full proof but good enough.
Explicitly routed frameworks are common nowadays, implicitly routed like vanilla less so. There is an argument for backwards compatible explicit routing in vanilla.
In vanilla route=rewrite/redirect, however actual routes are fully reversible, the basis to which framework like django determine urls and map architecture.
