Image optimization plugin for faster page load speed.
Prosper
Is there any image optimization plugin for vanilla forum that can meticoloudly scan all uploaded images and cut down unnecessary bytes making images and webpages load faster?
Example of this plugin for word press is "WP SMUSH" - URL is https://wordpress.org/plugins/wp-smushit/
Can this plugin be developed for vanilla forum?
You can do that already by reducing the allowed upload amount. So people do not upload huge files.
Generally that is the purpose for using thumbnails. If you insert an image into the post instead of just having the thumbnail, it will affect the loading of the page. Reducing the amount of comments and discussions from each page, speeds up loading in general.
You could also have your users compress their images before uploading
https://compressor.io/compress
@vrijvlinder - Thank you for your comments. I have actually setup max image size and dimensions to upload on config.php
However, uploaded images that passes image size and dimensions requirement still need optimization. Is there a way of using an API from an image optimization service to scan and optimize all upload images on vanilla forum. That way, forum users can upload images without slowing down website speed.
You could either implement a cron job to process the images or hook into the File Upload plugin and optimize them in place.
The FileUpload plugin fires an event when an image is uploaded. Hook into
Gdn_Upload_SaveAs_Handler($sender)
and optimize the temporary image. Here is the pertinent lines you would need to re-implement if you can't do it in place: https://github.com/vanilla/addons/blob/301a22488311806e0763e1f855473f04c3e06623/plugins/FileUpload/class.fileupload.plugin.php#L837-L862Search first
