Problem with Form plugin
edited February 2016 in Vanilla 2.0 - 2.8
Grettings
I downloaded this plugin: https://vanillaforums.org/addon/howtoformvalidate-plugin
When enable the plugin, I can access the Form from the link is added to the menu and everything works fine in the Form:
but the problem is I can't no longer access the discussions and I get the following error:
When I remove this code I can access the discussions but this makes the link is not added to the top menu.:
public function base_render_before ($sender) { // We only need to add the menu entry if a) the controller has a menu // and b) we are not in the admin area. if ($sender->Menu && $sender->masterView != 'admin') { $sender->Menu->AddLink('', t('Form & Validation'), 'vanilla/HowToFormValidate'); } }
How I can fix this? I want to have the link on the top menu and have access to the discussions.
Sorry for my bad english btw.
    R_JR_J Ex-Fanboy Munich Admin
    Thanks for that feedback! You have to change if ($sender->Menu && $sender->masterView != 'admin') { to if ($sender->Menu && $sender->MasterView != 'admin') {. I'll update the plugin as soon as possible.
    By the way: if you go to the plugin download link https://vanillaforums.org/addon/howtoformvalidate-plugin there is a button for asking a question. If you use that, the plugin author gets a notification.
