how to add rhe adfly extension (help)
RedWulf
Hello i would like to add this code to my fórum but how can i sorry um kinda newbie on those stuff
var adfly_id = 14412683; var adfly_advert = 'int'; var adfly_protocol = 'http'; var adfly_domain = 'adf.ly'; var domains = ['depositfiles.com','rapidshare.com','vip-file.com']; var frequency_cap = '5'; var frequency_delay = '5'; var init_delay = '3'; var popunder = true;0
What exactly do you need to do beside adding this code, use adds ?
You need to use the pocket plugin to add content to your forum. be careful that certain scripts might be harmful …
try this one specifically for adverts https://vanillaforums.org/addon/aptads-plugin
All right thanks im gonna do it right when i get on a computer
