How to speed up my website?
VanillaBoy91
Hey guys, have you noticed if Vanilla slows down the overall load time of your website? Also what are some other tips for optimizing my website speed?
Hi,
Link please.
here you can see how to optimize your webpage loading time: https://gtmetrix.com/
@VanillaBoy91
There's no simple answer to that question, as it will depend to a great extent on your hosting situation.
If you have the required access, you would probably benefit from setting up Memcached and OPCache (see here: https://github.com/vanilla/vanilla-docs/blob/master/docs/developers/backend.html.md )
I was only able to set these up after moving to a VPS hosting solution, as my previous host didn't allow the server access needed to set them up.
Personally, I use that plus the free CloudFlare option.
There is, sadly, no one size fits all solution.
Avoid themes that load resources from lots of 3rd party sites. look at default.master.tpl , themehooks, css and keep slow 3rd party sites from hogging resources. also avoid performance hogging plugins.
Pragmatism is all I have to offer. Avoiding the sidelines and providing centerline pro-tips.
The site is offline now, it will online in about a week:/> @whu606 said:
Thanks for the link, will check it out now.> @River said:
Thanks for this!
