  • np January 2011
Who's Online 14
ericgilletteperegrine422 +11 guests
Character encoding problem after moving from Vanilla 1 to Vanilla 2
I migrated my forum from Vanilla 1 to Vanilla 2. I used the vanilla2export.php to move the data over. Previous non-ASCII data is no longer displaying correctly. It showed fine in Vanilla 1.
My tables are UTF-8. I can see the correct data when using an SQL client in UTF-8 mode. The data shows up the same way in the Vanilla 2 tables as it did in the Vanilla 1 tables. Additionally, the non-forum part of my site also does UTF-8 correctly.
When I add a new comment that includes non-ASCII characters, it shows up correctly on the forum, but incorrectly in the SQL client.
My pages are being with HTTP headers specifying UTF-8. I've seen this page, which says that there are various settings for character encoding. It's for Vanilla 1, but looking at my config files, I see that I have no character-encoding-related settings in config.php, and config-default.php has:
$Configuration['Database']['CharacterEncoding'] = 'utf8';
$Configuration['Database']['ExtendedProperties']['Collate'] = 'utf8_unicode_ci';
$Configuration['Garden']['Charset'] = 'utf-8';
What do I need to do to make this work right?
  • npnp
    After some more digging, I found that despite the fact the tables are UTF-8, the Vanilla 1 connections were being made in latin1. The comments from Vanilla 2 are encoded correctly.
    My MySQL client was connecting with the DB's default encoding, which was latin1. If I ran "set names utf8" then I saw Vanilla 2's stuff showing up correctly, and Vanilla 1's stuff incorrectly. My non-Vanilla code also had the same problem.
    To fix, I made this PHP script to convert the old data. The IDs used represent the cut off between the Vanilla 1 data and the Vanilla 2 data.
    <?php
    # make iconv shut up
    #error_reporting(E_WARNING);
    header( 'Content-Type: text/html; charset=UTF-8' );
    $db = mysql_connect('localhost', 'root', 'password');
    mysql_query("USE mydb");
    mysql_query("SET NAMES latin1");
    #$result = mysql_query("SELECT DiscussionID, Name FROM GDN_Discussion WHERE DiscussionID <= 24460");
    $result = mysql_query("SELECT DiscussionID, Body FROM GDN_Discussion WHERE DiscussionID <= 24460");
    #$result = mysql_query("SELECT CommentID, Body FROM GDN_Comment WHERE CommentID <= 50053");
    $stuff = array();
    while ($row = mysql_fetch_row($result)) {
    $stuff[$row[0]] = $row[1];
    mysql_query("SET NAMES utf8");
    if ($stuff[$row[0]] == $row[1]) {
    unset($stuff[$row[0]]);
    #echo $row[0].'<br>';
    foreach ($stuff as $key => $value) {
    $value = iconv('UTF-8', 'UTF-8//IGNORE', $value);
    # echo $key.' "'.htmlspecialchars($value).'"<br>';
    # mysql_query(sprintf("UPDATE GDN_Discussion SET Name = '%s' WHERE DiscussionID = %s", mysql_real_escape_string($value), mysql_real_escape_string($key)));
    mysql_query(sprintf("UPDATE GDN_Discussion SET Body = '%s' WHERE DiscussionID = %s", mysql_real_escape_string($value), mysql_real_escape_string($key)));
    # mysql_query(sprintf("UPDATE GDN_Comment SET Body = '%s' WHERE CommentID = %s", mysql_real_escape_string($value), mysql_real_escape_string($key)));
    mysql_close($db);
