Merge and Split discussions - possible?
edited May 2011 in Vanilla 2.0 - 2.8
I am helping someone with their Vanilla board (completely new to it) and we cannot seem to find an option in Vanilla to split or merge a discussion - is it not implemented? Is there a plugin for it? Or maybe its possible to write on (I am a PHP dev so if theres nothing out there I'll just write something but it's the hard way)
    Can you write a plugin that splits and merges threads?
    There's no possibility to split and merge threads at the moment.
    I am currently working on a plugin, but as I am completely new to Vanilla, it can take a long time before I figure out how to use the framework. So far I managed to inject split/merge buttons using a plugin and DiscussionController_CommentOptions_Handler method. Now Im trying to figure out how to plug any actual logic under these buttons
    At this point working on merge stuff in my plugin this is what I have:
    1. a link next to the first post linking to eg. /discussion/merge/32273
    2. a method in plugin DiscussionController_merge_Create
    And I am stuck not knowing how to invoke a view, where I could try rendering a form
    $Sender->View = 'merge';
    $Sender->Render();
    OK that was pretty obvious. I think I am on a good path
    lucluc ✭✭
    http://vanillaforums.org/discussion/15420/merge-discussion-threads-in-vanilla-2#Item_3
    Not sure about split.
    And maybe it wasn't on the "Garden" github, but the one with addons. I'll try to remember to have a look tomorrow.
    lucluc ✭✭
    Yep, it's in the regular Garden github repo.
    'Name' => 'Split / Merge', 'Description' => 'Allows moderators with discussion edit permission to split & merge discussions.',
    => https://github.com/vanillaforums/Garden/tree/unstable/plugins/SplitMerge
    As far as I can see its pretty useless anyway because the plugin uses framework elements that are not in Vanilla, it wopuld require me to hack the entire forum inside out but maybe i can use some of it to write an actual plugin
    lucluc ✭✭
    It might just use elements that are in unstable that's all.
    I don't see the core dev creating and pushing to github something useless.
    Its not useless in general, but it just has no application in my case. I would need to move a lot of unstable code to the live install to make it work, and it would probably not work.
    But I can try figuring out how the logic is supposed to work, and use it in my own plugin that would work on stable Vanilla
