Fork me on GitHub
Please upgrade to 2.1.x here. The 2.0 branch is no longer being updated.
Critical: Update to 2.1.8, released 15 Jan.
Tagging plugin problem with Urls
SevMCSevMC
edited February 2012 in Vanilla 2.0 Help
Hello!
I've modified the .htaccess and added the following rules:
 RewriteRule ^post/discussion(.*)$ /post/sound$1 [R,L]
 RewriteRule ^sound(.*) index.php\?p=post/discussion$1 [PT,L]
The problem is that the tagging box doesnt apear when someone tryes to create a discussion because it is not the normal URL I think the problem may be here, but I don't know how to fix it:
    * Add the tag input to the discussion form.
    * @param Gdn_Controller $Sender
   public function PostController_BeforeFormButtons_Handler($Sender) {
      if (C('Plugins.Tagging.Enabled') && in_array($Sender->RequestMethod, array('discussion', 'editdiscussion'))) {
         $Discussion = GetValue('Discussion', $Sender->EventArguments);
         if ($Discussion && !$Sender->Form->IsPostBack()) {
            // Load the existing tags.
            $Tags = Gdn::SQL()
               ->Select('t.*')
               ->From('TagDiscussion td')
               ->Join('Tag t', 'td.TagID = t.TagID')
               ->Where('td.DiscussionID', GetValue('DiscussionID', $Discussion))
               ->Where("coalesce(t.Type, '')", '')
               ->Get()->ResultArray();
            $Tags = ConsolidateArrayValuesByKey($Tags, 'Name');
            $Sender->Form->SetValue('Tags', implode(' ', $Tags));
         echo $Sender->Form->Label('Tags', 'Tags');
         echo $Sender->Form->TextBox('Tags', array('maxlength' => 255));
I'e fixed the problem with the voting pluggin just changing this:
$VoteUpUrl = '/sound/'.$VoteType.'/'.$ID.'/voteup/'.$Session->TransientKey().'/';
$VoteDownUrl = '/sound/'.$VoteType.'/'.$ID.'/votedown/'.$Session->TransientKey().'/';
But is not the same with this one
  • x00x00 MVP
    edited February 2012 Answer ✓
    try changing
    to
    in_array($Sender->RequestMethod, array('sound','discussion', 'editdiscussion')
    what you are doing is precarious, I'm not saying don't do, just you will be fire fighting.
    Ask yourself "is it really worth the hassle?"
  • x00x00 MVP
    try changing
    to
    Well yeah, it maybe doesn't worth it now, but maybe later I will customize a lot the system when the community grows up, in order to make it more "original". As the concept of the project is not realy a "forum", maye I will need to change the URL's later in order to be more accurate with the concept. I know it will be complicated to change the whole system in order to realy change them, but maybe in that moment will worth it.
    Sorry for my bad english, it is not my first language.
  • x00x00 MVP
    There is a possible way to do it but it is more complicated than you think, not simple. People rely on Controller, RequestMethod, OrigionalRequestMethod, RequestArgments, and also they may simply not use the supplied methods, an rip it out with hacky php.
    if there is interest in localising the uri , be it categories, and other controllers, plus methods, then feel free to sponsor the project.
  • Thanks for the sugestions :)
