Twitter issue : SSL is required
Hello everybody,
I installed Vanilla 2.1b1 on my server (1and1) and I've tried to get Twitter working properly since. I still get the message "SSL is required" when I try to register using Twitter. The URL of my forums is : http://www.playmag.fr/forums
My consumer key and consumer secret are correctly entered in the admin.
Any idea of what the problem is ?
Thanks in advance.
  • The API calls need to be made over https, IIRC.
    You can find more info here: http://vanillaforums.org/discussion/comment/202904/#Comment_202904
  • Problem solve. Thanks a lot!
  • Hi There,
    Kind of a newb here, so sorry if I am missing something.
    I was having the same of ["SSL required"] for the twitter same twitter login issue as the OP. I have folllowed the link to the link and corrected code by hgtonight, but the class.twitter.plugin.php seems to have changed, as my version not the same as the linked code.
    I have installed vanilla version 2.0.18.10. Here my pligininfo array, which is not compatible with the fix linked to. Am I missing something here?
    // Define the plugin:
    $PluginInfo['Twitter'] = array(
            'Name' => 'Twitter',
       'Description' => 'This plugin integrates Twitter with Vanilla. <b>You must r$
       'Version' => '0.1a',
       'RequiredApplications' => array('Vanilla' => '2.0.12a'),
       'RequiredTheme' => FALSE,
       'RequiredPlugins' => FALSE,
            'MobileFriendly' => TRUE,
       'SettingsUrl' => '/dashboard/settings/twitter',
       'SettingsPermission' => 'Garden.Settings.Manage',
       'HasLocale' => TRUE,
       'RegisterPermissions' => FALSE,
       'Author' => "Todd Burry",
       'AuthorEmail' => 'todd@vanillaforums.com',
       'AuthorUrl' => 'http://www.vanillaforums.org/profile/todd'
  • MVP
    edited April 2014
    @mbjvfx the issue is Twitter made is so all calls to the api need to go to https. So just do a CTRL+F in the file and make sure all links to Twitter that show HTTP, now show HTTPS
    find
    public static $BaseApiUrl = 'http://api.twitter.com/1.1/';
    to
    public static $BaseApiUrl = 'https://api.twitter.com/1.1/';
    find
    $Url = "http://api.twitter.com/oauth/authenticate?oauth_token={$Data['oauth_token']}";
    to
    $Url = "https://api.twitter.com/oauth/authenticate?oauth_token={$Data['oauth_token']}";
  • Thanks Adrian Will do
  • Fixed my issue too.
