Make FirstLastNames work along with Add Question Registration
Hi jspautsch,
I am writing you because I am trying to combine your plugin with either botstop or Add question registration addons.
Apparently, they do not work out of the box since - once FirstLastName is active - the other two stop functioning.
By the look of it, I think it should be possible to fix it by adding inside your plugin some references to (say) Add Question Registration.
Can you help me in doing that?
I am not at all an expert in PHP (just starting to learn it) and I am also far from being an expert on Vanilla but, by the look of it, I think that the solution might be to insert into "class.firstlastnames.plugin.php" what is coded in "default.php" of Add Question Registration plugin (http://vanillaforums.org/addon/addregistrationquestion-plugin) .
Could you help me in accomplishing that?
Because I am really not able to do it on my own.
Thank you and great job with your plugin!
It is going to be extremely useful for the forum I'm trying to build.
Best,
Matt
